-   Ford Escape (https://www.fordforum.com/forum/ford-escape-19/)
-   -   Coolant issues (https://www.fordforum.com/forum/ford-escape-19/coolant-issues-45167/)
Yamavstar Feb 22, 2022 09:28 AM
Coolant issues
2004 Ford escape.
I have the radiator drain plug out;bottom radiator hose off..plastic reservoir is full of water,coolant but not draining ..still full.
Any suggestions..ideas..possible cures?
raski Feb 22, 2022 10:58 AM
It needs a vent to allow air in as coolant escapes. Did you try removing the UPPER hose too? Are you positive the radiator is full?
Yamavstar Feb 22, 2022 11:03 AM
Upper hose,no.no drain plug on radiator and bottom hose off.should be plenty to vent.radiator obviously is empty.
hanky Feb 22, 2022 11:34 AM
Yamavstar,
How about we get the reason you started this whole thing?
What really happened and did you determine just what ?
I'm pretty sure there is a lot more to know before offering and ideas, what do you think? thanks.
Yamavstar Feb 22, 2022 11:56 AM
What prompted this was overheating.but the reservoir was still at a good level.i believe the prob was this.found one of these in the reservoir blocking the outlet to radiator and when I took off hose from reservoir to radiator found what I'm gonna call deer turd looking things.test drive here after a beer...lol
https://cimg0.ibsrv.net/gimg/www.for...691ede116f.jpg
https://cimg7.ibsrv.net/gimg/www.for...26ff771628.jpg
Yamavstar Feb 22, 2022 12:09 PM
Posted more..waiting for moderator to clear my attachments.
scott.butler4 Feb 22, 2022 02:40 PM
While waiting for pictures to load I would recommend pouring water in the radiator fill and seeing what comes the open radiator drain. Mostly just to see what happens.
Yamavstar Feb 22, 2022 02:43 PM
Once again...the reservoir will not drain.pics will clarify.
scott.butler4 Feb 22, 2022 06:04 PM
Ohh I didn't realize that year didn't have a radiator cap. The coolant reservoir cap does need to be removed though.
Yamavstar Feb 22, 2022 06:16 PM
Uh....ya..realize that.
thanks.
