rmanick1 |
03-27-2012 11:23 PM |
Cooling Fans will not Operate - 2009 Escape - HELP
I recently bought a 2009 Escape with a 6 Cylinder Engine. I drove it a couple months when it was cooler outside and had no problems. Now that it was warmer outside I turned the a/c on. While idling for a period of time, I saw a big puff of white smoke come from the engine. I subsequently determined that the air conditioner relief valve released some Freon since the a/c was overheating because the cooling fans were not coming on.
Now the problem: I cannot figure out why both cooling fans will not operate. I jumped the wires to the fans and they both run properly. I checked both fuses in the fuse box and they are fine. I also replaced all three relays in the fuse box, but the fans still will not turn on. All the wires are wrapped up, so I do not believe that there is a broken wire, besides the car is too new. It is my understanding that the passenger side cooling fan is suppose to operate when the a/c is turned on, so the problem cannot be the coolant sending unit. I was told that there is suppose to be another cooling fan relay somewhere, but I have not been able to locate it. Does anyone know where that relay is located? Also, any additional help on solving this problem would be greatly appreciated. I really don't know what else to check. Thanks in advance!!!
