Ford Escape ABS Problem
Old Aug 16, 2009 | 04:20 PM
Lone Eagle's Avatar
Default Ford Escape ABS Problem
I have a 2002 Ford Escape 2WD V6. EAch time when first moving from parked, the ABS system kicks in and modulates the brakes. This happens once or twice, then the ABS light comes on, the ABS quits modulating the brakes and the car brakes normally. It is as if the ABS system thinks it needs to operate and does so for a couple of cycles, then gives up, lights the light and (I assume) turns off the ABS and works without it. Any ideas what this could be and how to troubleshoot the system?
gk24
Oct 3, 2014 10:41 AM
mgan9311
Jan 5, 2012 07:00 PM
patrick8771
Jan 5, 2012 06:51 PM
luvmine
Jan 4, 2008 10:38 AM
Hutch64
May 31, 2007 09:21 PM
