Grinding in right front
Old Dec 14, 2024 | 01:30 PM
kmalone5859's Avatar
Smile Grinding in right front
I have a 2014 Escape Titanium with only 70,000 miles. It's never had any problems at all. Now, it has a grinding noise and/or slipping in the right front axle. It's only when accelerating and it goes away after you've driven for 20 miles or so. It's hard to tell whether it's actually slipping, but it sure looks like the tach is too high. Forums say a bad CV joint will make popping sounds but that is not happening here. Could this be the CV joint or maybe the transmission?
Old Dec 14, 2024 | 04:35 PM
Can you check if the trans fluid smells overheated or burnt?
Old Dec 14, 2024 | 06:04 PM
Default Fluid is burned
Yes, it is. Badly. I assume it's supposed to be red. It's black and smells burned. (I cleaned off the oil dipstick and stuck it into the fill port.)
I also noticed the brake discs were very hot, though I didn't compare the front to the back.
Old Dec 15, 2024 | 08:14 AM
When the trans is slipping internally, it is generating heat which is an automatic's worst enemy. A rebuild is close up the road. Waiting , could include a towing fee.
Old Dec 15, 2024 | 08:22 AM
Well, that's bad news. But thank you for the advice. I appreciate it.
Old Jan 13, 2025 | 02:09 PM
Update - a transmission guy noted that the tranny is on the driver's side in this car and said the fluid on ALL of them seems burned. Given that the noise is on the passenger side, I dug deeper and found posts that suggested the problem was the passenger side motor mount. Sure enough, that was it! Fixed for under $500. I don't know exactly what was scraping, but it stopped.
Old Jan 13, 2025 | 05:18 PM
Thanks for the update.
evan
Feb 15, 2024 08:41 PM
btarb24
Jul 12, 2023 04:52 PM
Habslover70
Oct 7, 2021 10:07 PM
jawright79@hotmail.com
Oct 3, 2016 04:32 PM
highpowerd2003
Mar 21, 2007 01:56 PM
