Rear Door/Glass Actuator
I have a 2010 Ford Escape XLT with a broken plastic link on the actuator for the rear door. The actuator itself still worked so I bought the plastic piece that is identical to the ones used on GM vehicles. It is a dorman product. Note: I couldn't find just the plastic link as a Ford or Dorman product part. Anyway, after installing the new part the door works fine now but I am still getting an error message on the dash that the rear door/hatch is ajar even though it is not. Also, at the same time the inside light started staying on and I have to manually turn them off every time we exit the car. I have checked the wiring harnesses in the door to make sure everything was connected and it is. Anybody ran into this issue before?
Thanks, John |
Which door latch did you work on?
Here is the wiring diagram, I can post connector images depending on which door. You can jump out pins 5 and 6 to see if the door ajar light goes out. https://cimg9.ibsrv.net/gimg/www.for...c4f041eeab.png |
