right rear -clicking when braking
Old Nov 19, 2025 | 09:27 AM
dugray's Avatar
Default right rear -clicking when braking
2011 escape AWD, clicking from right rear when braking, replaced brake shoes/new drum , new wheel bearing, only when braking theres a clicking sound coming from right rear area.. is it possible the hub may be tweaked? any suggestions, tia…
Old Nov 19, 2025 | 10:59 AM
That noise is trying to tell you something.
You will need to remove the wheel and drum and chances are a spring may have popped off.
REGARDLESS,,,,,,,, if it causes damage to the hydraulic system you could lose some braking power.
When you replace shoes etc, you should replace all hardware for that wheel because it is all exposed to high heat and the cost is not that much.
mikepardes
Jun 7, 2022 11:33 AM
Richard Reale
Feb 6, 2021 07:42 PM
MaggieC
Jul 16, 2019 01:54 PM
David Wellman
May 5, 2017 07:22 AM
matt105
Jul 7, 2008 01:26 PM
