93 esort wagon bad hisitation
Old Jul 5, 2022 | 01:02 PM
hick.man's Avatar
Default 93 esort wagon bad hisitation
hey all, I have a 93 escort wagon, manual transmission that when you accelerate it falls flat on its face for a second or 2, then revs up . does it real bad at highways speeds at about 50-60mph. I cant seem to track it down. has anyone else experienced this?
thanks
Old Jul 5, 2022 | 01:36 PM
raski's Avatar
I would normally say to check for codes first but on a 93, the information will be very limited. I would start with checking the fuel system. Items include fuel pressure which sould be about 40 psi and the fuel filter. I am assuming your 93 has a throttle body injection with the shrader valve being on the throttle body.Fuel fiter should be very easy to change once the pressure is relieved via the shrader valve.
Lastly, a problem could exist with the throttle position sensor. That can be easily checked with an ohm meter. Look for "dead spots" as the sensor is slowly rotated.
Old Jul 5, 2022 | 01:50 PM
hick.man's Avatar
thanks for the reply i will check, ive never tested a tps, you wouldnt happen to have a link on a tutorial would ya?
Old Jul 5, 2022 | 02:31 PM
hick.man's Avatar
i just unplugged the mass air flow sensor, fired it up and no hesitation, it reved up fine. plugged it back in and the hesitation returns. so bad maf ?
Old Jul 5, 2022 | 04:54 PM
hick.man's Avatar
fixed!, was the MAF, thanks for the help.
Old Jul 6, 2022 | 06:43 AM
raski's Avatar
That's good. I would keep the old one as a spare. It's wire may just need to be sprayed (cleaned ) with MAF cleaner.
ucatch2000
Dec 20, 2009 01:54 PM
kraemer878
Nov 30, 2008 02:51 PM
Eric334
Apr 2, 2008 03:06 PM
Tacoma750
Dec 27, 2006 06:17 PM
gatcaulk
Mar 1, 2006 02:25 PM
