95 wagon coolant temperature
1 Attachment(s)
I have a 95 wagon with 1.9L engine and don't know if the fan is working. The gauge on the dash doesn't go further than center, but the engine and the coolant seem to get very hot.
Had quite some pressure in the upper radiator hose Thermostat is new, OTC monitor tested fan and relais good The small unit on the pic is the sender for the gauge Is the bottom one the engine coolant temperature sensor, and is it responsible for starting the fan and what are the specs of the two? I appreciate any help and suggestions |
2 Attachment(s)
Just in case somebody is interested -found some data about sender and sensor
1996 Ford Explorer. Small coolant leak only when the truck is off or cold.
Doesnt leak when it is at 200-220 degrees. Not much coolant but any coolant leak would be ideal of course. I can find where is coming from, but it looks where the lower hose goes into radiator. But wouldnt it leak all he time?Any ideas please? thanks |
I dont know if you can trust the resistancies of the sender I posted earlier
I couldn't find any with 500 ohms cold and 17 ohms hot, but I put a Standard Motor Product TS 300 in that measured at about 2.5 Kohms cold and it seams to work, although the gauge worked fine when i probed it with resistors Very strange |
Originally Posted by MagicOPromotion
(Post 46067)
Doesnt leak when it is at 200-220 degrees. Not much coolant but any coolant leak would be ideal of course. I can find where is coming from, but it looks where the lower hose goes into radiator. But wouldnt it leak all he time?Any ideas please? thanks -But this are only ideas- |
