Blinker Stuck On
Blinker Stuck On
Hey guys. My friend is going to drop of his car tomorrow for me to look at. From the sound of it his blinker is stuck on. Two things that came to mind are either a bad relay or bad turn signal switch. Figured I would try the relay first as that would be a cheap fix.
I was wondering if anyone could clue me in on the location of this relay? Is it under the kick panel on the drivers side? Or is there somewhere else I should look?
Thanks,
John
Thanks,
John
So I found this diagram:
Where is the flasher on 94 mercury tracer? - JustAnswer
Please tell me there is a trick to getting to this without taking the entire dash off? I popped the kick panel off and the steering column and cant seem to locate them from there.
