98 F150 blinker issue
Old May 21, 2006 | 07:33 PM
kerwinq's Avatar
Default 98 F150 blinker issue
The right blinker is not working when the steering wheel is in the down position. If the steering wheel is in an upper position all seems to work fine. The left works with the wheel in any position. Is this in the switch in the column or possibly somewhere else?
Thanks, Kerwin
Old May 22, 2006 | 12:49 PM
Bullitt94's Avatar
Default RE: 98 F150 blinker issue
Sounds like a short in the switch somewhere...
Old May 22, 2006 | 10:54 PM
kerwinq's Avatar
Any idea what the cost is to replace the switch?
Old May 23, 2006 | 12:55 AM
Bullitt94's Avatar
Just a guess, but if you have a shop do it I'd say around $100. You can probably buy the part for about $40. You could even call a junk yard to see if they have the part for your truck. It would be pretty inexpensive then, I would think. I'm just guessing at prices, so please don't hold me to it.
Old May 23, 2006 | 09:24 PM
hockeyhitman69's Avatar
first check your wires into your multifunction switch for a pulled out pin because if it works fine when your steering is up and not when it is down then you lost contact ..then check the multifuction switch
Old May 25, 2006 | 09:50 AM
kerwinq's Avatar
Where is the multifuntion switch located? I just got the truck so this is all new to me
Thanks
Old May 27, 2006 | 11:06 PM
kerwinq's Avatar
At first thought, I thought this was a switch under the dash. Now I know better!! How do I get to the wiring to check this? Do I need to pull the steering wheel or is it just a matter of unplugging the switch?
Thanks for the help, Kerwin
Old Jul 13, 2006 | 01:37 PM
rustypierce's Avatar
I see you have the same issue as me with your turn signal. My right turn signal blinks super fast, however not all the time. I have replaced the flasher unit and it still does not work properly. I am starting to think it's the multi function switch. How did you replace your multi function switch?
Also how do I check the pins in a multifunction switch?
Old Jul 14, 2006 | 01:25 AM
mexiburger's Avatar
check the bulbs and grounds to the lights... I have had one side blink really fast on alot of vehicles and it was just because one bulb wasn't working.
Old Jul 14, 2006 | 03:54 PM
That is a good idea on checking the bulbs and grounds before I tera apart the steering column. I am going to have to do this on left and right side now because the same issue is hapening on both sides, however the emergency flashers work fine? Go figure!
