Help! 98' ZX2 Escort, Brakes feel very weak
Old Sep 1, 2013 | 07:46 PM
Versic's Avatar
Question Help! 98' ZX2 Escort, Brakes feel very weak
Hi, I just bought a 98' escort as a beater car to get me to and from work. When i was inspecting it, I found that the rear brake hoses needed to be changed and so I did using Napa brake hoses + lines ( lines were rusted to hell too.) Rear brakes were then bled as well.
But afterwards, brakes seemed extremely weak and have to be pressed to the floor to even begin braking. Did not have this problem before and I had Ford journeyman helping me with the issue so I know it wasnt just me failing at installing the brake hoses / lines. Any ideas on what could be causing it would be extremely appreciated.
Old Sep 1, 2013 | 09:01 PM
greasemark's Avatar
It might be a good idea to get the system pressure bled, which would elimnate any air in the system.
This sometimes happens in older cars when the system is opened for the first time (probably ever). I've seen a lot of master clyinders go bad this way.
Old Sep 7, 2013 | 08:32 PM
twj815's Avatar
Sounds to me like the master cylinder might need to be bled first then re-bleed all four wheels. After replacing brake lines there will be a lot of air in the system.
squad272
Mar 5, 2014 01:16 PM
Adrescher7
Jan 25, 2012 07:37 PM
Driver Tom
Nov 12, 2008 08:03 PM
dannyr2006
Sep 17, 2008 04:35 PM
