how to adjust the idel down 91 escourt gt
Old Apr 27, 2008 | 09:12 PM
coojoe's Avatar
Default how to adjust the idel down 91 escourt gt
My idel is stuck at 2,000 takes a half hour or more to drop down is there anything i can do to adjust this problem.
Old Apr 27, 2008 | 11:04 PM
Default RE: how to adjust the idel down 91 escourt gt
Any check engine light?
First thing to suspect would probably be the IAC (idle air control), or vacuum leaks into the intake, possibly the throttle plate/shaft itself.. The throttle position is factory set, and even if the set screw was backed completely out, it won't slow to an idle from 2K.. The PCM is in control of the idle air volume with the idle air control valve.. With it high idling, unplug the IAC and see if the engine RPMdrops.. Think this pic is correct for the 1.8
[IMG]local://upfiles/6756/F5DC4115956A41669061BB62859BE093.jpg[/IMG]
BIGHOTS
Dec 17, 2012 09:51 AM
eddiedtsr@yahoo.com
Dec 22, 2010 08:10 PM
skip
Mar 13, 2008 10:46 PM
rayjolly
Nov 22, 2005 03:02 PM
Moon
Aug 28, 2005 03:46 PM
