My Escort engine died
Old Jan 24, 2006 | 03:13 PM
Falling Rock's Avatar
Default My Escort engine died
My 1996 Escort (1.9 with Automatic) died over the weekend. Came home and the enginge started rattling or more like knocking then died. It will start for a few seconds but sounds like something rattling around in the engine. #4 plug was very wet with gas.
I changed the timing belt thinking it may have jumped a tooth or two. It had 56K miles on it. I bought it new in 96 and has had regular maintanace and oil changes with pure synthetic oil. Except a few weeks ago when my wifey got it changed and she didn't tell em to use synthetic oil and they used regular dinolube.
Anyways after I did the belt change it still knocks and then dies.
It's actualy knocking sound
So far the shade tree mechanics in my block say it's either :
Bent valve (doubtful as timing belt was still ok when replaced)
Bent rod (never raced it. It's been my daily driver)
Borken flexplate/flywheel
Sticking starter.
Help.
Old Apr 13, 2006 | 09:17 PM
bulletstopper's Avatar
Default RE: My Escort engine died
Have you checked your compression yet? It could be a blown head gasket. Mine blew out between two cylinders. I have 160psi in two and 50psi in the other two. When I go up hills it loses all power. Plus the engine barely idles, and rattles if it revs up.
kevin_rmx
May 27, 2012 01:40 AM
Engloid
May 21, 2006 09:44 PM
2001platinum
May 5, 2006 02:45 PM
funkdoobiest
Feb 11, 2006 05:16 PM
skeetski
Sep 25, 2005 05:53 PM
