'04 Excursion Won't Start
Old May 2, 2009 | 12:42 PM
jrc411's Avatar
Unhappy '04 Excursion Won't Start
The wife's '04 Excursion will not start this morning. No power to lights, windows, seats, door locks, etc. Turn the key and you get nothing, not even a cellinoid clicking. She drove home from work last evening 30 minutes with no problems and no warining lights.
Put the charger on this AM for 1 hour @ 16.5 amp setting. Meters on charger are showing 4 volts and 6 amps respectively after 1 hour, but still no power of any sort.
My guess is fuse/circuit breaker or relay. So if this is the problem, here are my questions:
1) Which are the likely faulty circuit I should test
2) Checking a fuse is pretty simple, but if it is a relay, how do I test it.
Thanks for your help. Of course SHE has my truck until I can get her SUV fixed!!!!!!!!!!
JC
Old May 4, 2009 | 03:52 PM
moneymaker's Avatar
engine?
Old May 14, 2009 | 09:34 PM
marcelozanetti's Avatar
Hi JC,
I'm having the same problem you are/had. Can you please let me know if you got any answers for your questions? I really appreciate your feedback.
Thanks,
Marcelo
Old May 28, 2009 | 10:15 PM
JAKENLOU's Avatar
Default Won't start?
Was the gear shift all the way in park? Sometimes it gets stuck between park and reverse and it will not start.
marc0820
Jul 22, 2019 05:51 PM
Laura W
Sep 21, 2010 08:33 PM
cglad1
Apr 10, 2007 03:29 PM
2excowner
Dec 6, 2005 04:47 PM
wwjd216
Jun 7, 2005 06:43 PM
