2001 A/C question
Old Jul 19, 2009 | 09:24 AM
Starcloud's Avatar
Default 2001 A/C question
The front A/C blows warm to cool, back A/C stays COLD!! One compressor, two cooling units. How is this possible? Not sure really when this started, but I believe it was shortly after replacing the water pump.
Checked A/C gas...OK.
2001 Limited, 7.3 L.
Any suggestions?
Old Jul 23, 2009 | 05:42 AM
Use Common Sense's Avatar
Front evaporator uses an orifice while the rear uses an expansion valve. I would suspect that either the front orifice is either plugged or you have moisture in the system causing the front orifice to freeze up. How was the freon checked?
BASSHAWK
Mar 28, 2012 02:27 PM
bdbctcg
Feb 3, 2009 07:50 PM
NLAlston
Apr 26, 2008 08:36 PM
eightiesrock1980
Jan 6, 2008 02:20 PM
BASSHAWK
Jun 15, 2007 09:32 AM
