2001 V-10 location of the IAT
do not put that POS chip in for the IAT , it will jack like 30 degrees timing in your truck which will make it ping like crazy , if you want to add power , get an aftermarket tuner for it , Sniper Special Forces will work on that truck , and then you can add timing and change the fuel curves for more power , without messing something up , and by the way if its its got 6 wires going to the mass air meter then the IAT is intergrated into the MAF ....
ORIGINAL: 2002BLGT
