Jump Start
Old Apr 2, 2007 | 10:11 PM
dgf625's Avatar
Default Jump Start
I jump started another vehicle then got in, and my Diesel Excursion was running, but gauges didnt work and it would not accelerate. I shut it off, it restarted still no gauges or acceleration. I turned it off again, and it wouldnt start I think because it ran out of fuel, because fuel pump was not running. Any one have any idea?
Old Apr 3, 2007 | 08:29 AM
enibum's Avatar
Default RE: Jump Start
I'm at work right now and can not look at my 01, but check to see if there is a fusable link connected to the positive side of the battery. This sounds like a possibility since you have no electrical functions other than starting the diesel. I would think that if you had a gasoline engine that it probably would not restart since there would probably not be anything to fire the sparkplugs. Hope this helps.
Old Apr 4, 2007 | 02:08 AM
goinstrong's Avatar
When connecting jumper cables on any newer vehicle ALWAYS use your owners manual so as not to fry the electrical system. Check fuses/fusible links first. Then look for overloaded circuits in any blown fuse/link wiring.
93f250xlt4x4
Jul 9, 2008 08:47 PM
JOverbey
Apr 25, 2008 04:32 AM
FordNutz
Dec 14, 2007 11:37 AM
daveranger
Dec 30, 2006 07:07 PM
rangerfx4l2
Oct 21, 2006 11:22 PM
