keyless entry codes
Old Nov 22, 2006 | 10:32 PM
drkeys's Avatar
Default keyless entry codes
Just bought a used 2000 excursion limited diesel with keyless entry. Does anyone know where to find the keyless entry code on the truck?
Old Nov 22, 2006 | 11:49 PM
Default RE: keyless entry codes
This is just a RKE system?, not PATS... There isn't a code card in the glove box handbook?..
Old Nov 25, 2006 | 02:39 PM
drkeys's Avatar
This is a remote keyless entry, but it has a key pad on the door. I don't have the code for the door. I bought the truck used and there are no manuals.
Old Apr 24, 2007 | 09:39 AM
psu152's Avatar
Remove cover under steering wheel/fuse panel. Shine flashlight rehind instrument panel towards the rear portion of the radio. There should be a stikcer on a cream colored box with the 5-digit code. Might hae to try looking in at different angles, but it should be in there. Different models, the box color is black, but htere is still a sticker behind the radio.
Old May 19, 2007 | 01:05 PM
jackrista's Avatar
ORIGINAL: psu152
NOT ON THE BACK OF RADIO BUT ON A BOX, THAT WILL BE THE CODE, HOW DO YOU SET A NEW CODE???
Old May 20, 2007 | 12:50 AM
Enter the factory security code, within 5 seconds press the 1.2 button on the keypad and enter any personal 5 digit code.. Each number must be entered within 5 seconds of each other.. The doors will lock and unlock to confirm the new programmed keycode..
Old Aug 9, 2007 | 04:54 PM
brighteyes811's Avatar
Hey guys, I just purchased a 2001 Ford Windstar Se and was not given the factory code for the keyless entry keypad. Does anyone know what this may be? I'd love to use this function. Thanks in advance for your assistance.
Old Dec 17, 2007 | 03:58 AM
batmanofasheville's Avatar
Thanks to all of you who answered drkeys question about the keyless entry code because it also helped me out with mine. The dealership wanted to charge $45 just to hook it up to the computer for a couple of minutes to tell me the code. However, it was easier for me just to remove the radio and look back in there and see the code insead of going from underneath. Again thanks.
Old Sep 1, 2008 | 06:10 PM
justjustin's Avatar
I took my 01 X in and the dealer said there was nothing they could do.
It seems I have a Ford Dealer installed system not factory installed.
My keypad on this one (3rd so far) is glued on the outside of the door
not snaped in like my first 2 looked to be.
Any ideas on this system and where to get the code or where they would install
the module for the keypad?
Justin.
leo2947
Mar 5, 2007 04:02 PM
Stryker
Nov 19, 2005 01:42 AM
93Miata
Nov 11, 2005 04:42 PM
mdbell
Sep 24, 2005 01:40 AM
ZMonte85
Jul 9, 2005 03:11 PM
