Odometer Problem
Old Mar 23, 2009 | 05:56 AM
Papa's Avatar
Default Odometer Problem
I have a 2003 excursion with a 6.0dsl. about a week ago my odometer stopped working displaying only "test" or "garbled numbers" (I think).
everything else in the cluster works fine. can anyone help me with this
Thank You
Papa
Old Apr 13, 2009 | 03:10 PM
oldtimer35's Avatar
You can try to pushing the reset button for the tripminder, with the key off, and then turn the key on. That should put the head into self test, you will have to push the button about a dozen times and it will go through different features until it finishes the test. At the end of the test, it may go back to normal operation, if not, time for a new head.
newt
Feb 6, 2016 07:53 AM
jeffro
Dec 30, 2010 08:49 PM
whiteface
Jun 25, 2010 01:52 PM
56PU
Nov 21, 2006 07:45 PM
xkikbxr
Mar 22, 2005 11:01 AM
