Stiff Brakes
Old Jul 30, 2008 | 04:58 PM
brooksa's Avatar
Default Stiff Brakes
hey guys new here and just curious if anybody else had this problem, brakes are in good shape and so are the rotors, the problem is the pedal is stiff, it takes a lot of pressure on the pedal for them to work. Even at a light on an incline I have to stand on them so I don't roll. Would a fluid flush make them any better or any suggestions? 0h 2000 110k
thanks
Old Jul 31, 2008 | 12:27 AM
jr78's Avatar
Default RE: Stiff Brakes
If it a gas motor, check to see if it is getting vacuum to the booster. Do you work on the truck or have it done??
Old Jul 31, 2008 | 07:17 AM
brooksa's Avatar
Yes it is a gas motor V10, sorry, and yes I can work on it myself, ok I will check that today.
thanks
Old Sep 23, 2008 | 03:29 PM
SnackMasterX's Avatar
I am having the same problem with my dad's excursion, he has a 2005 with the 6.0L turbo diesel, any suggestions or should I check the same things as with the gasoline engine?
Old Nov 11, 2008 | 12:06 PM
RosenhanClan's Avatar
My 04 with the V10 has a similar issue. Curious to hear responses.
coloradoyooper
Mar 27, 2011 08:01 PM
CORTINA302
Apr 11, 2005 02:22 PM
fishhead
Dec 2, 2004 12:48 AM
maiden_fan
Aug 4, 2004 03:10 PM
fishhead
Aug 1, 2004 06:23 PM
