04 Expy A/C Ghosts
Old Jun 17, 2015 | 01:16 PM
cypressdelight's Avatar
Default 04 Expy A/C Ghosts
My 2004 Expedition (Eddie Bauer) A/C has a poltergeist inside it. Whenever I put the A/C on Automatic and set the Temp the air flow immediately begins coming out the defrost vents then randomly shifts to the floor and dash vents before returning to the defrost vents where it stays. When I select the floor or dash vent buttons and manually set the fan speed, air flows from them briefly then goes to the defrost vents where it stays. I’ve replaced the A/C temp control unit TWICE and the problem persists. I need an exorcist to show me where I go from here to correct this problem.
Old Jun 18, 2015 | 11:14 PM
Use Common Sense's Avatar
Sounds like a vacuum leak in your vacuum system. The defrost position is the default position. Any vacuum leak where the damper control system can't hold vacuum, it will always end up in the defrost system. I would look under the dash for a loose or broken vacuum line. Especially the passenger side where folks tend to get their toes up under the dash.
BASSHAWK
Jun 15, 2007 09:32 AM
oregonn8v
Feb 14, 2007 08:14 PM
mi97tbird
Nov 27, 2005 07:27 PM
Kucimat
Sep 15, 2005 09:06 PM
carebear3030
Jul 21, 2005 10:11 PM
