2000 Expedition Front Rotor 12 mm or 14 mm
Old Feb 28, 2016 | 11:31 AM
brimis's Avatar
Default 2000 Expedition Front Rotor 12 mm or 14 mm
I need to replace the front rotors on my 2000 AWD Expedition 4.6L and I believe I have 14 mm studs due to a 13/16 socket fitting the lug nut.
I was asked if the truck was a hub or floating rotor. Can a member provide input as to which is the correct rotor for the truck?
As always,
Thank you
Old Mar 1, 2016 | 04:27 PM
LakelandFordParts's Avatar
Former Sponsor
I would be happy to provide you with the part number for your rotors. Is your vehicle a 4x4 or 4x2? If it is a 4x4 with M12 studs then you need XL1Z-1125-AA (#XL1Z1125AA: Rotor.), if you have the M14 studs then the part is obsolete.
retiredlarry
Oct 24, 2007 01:02 PM
crashxnxburn
May 5, 2007 02:37 AM
crashxnxburn
May 1, 2007 11:47 PM
DoctorAuto
May 23, 2006 09:32 PM
DoctorAuto
May 20, 2006 09:23 PM
