2003 expidition
Old Sep 7, 2011 | 07:34 AM
fgservice's Avatar
Default 2003 expidition
I have know power to fuel pump but I have key on power to fuel shut off. also no voltage reference to cam or crank sensor
Old Sep 7, 2011 | 08:27 PM
I believe you won't show any power to the crank or cam sensors because they generate their own signal when engine is turning over.
Also if its a 5.4L ,the PCM power relay energizes when the key is turned on to send power to the fuel pump circuit through the inertia switch. You might want to check out that PCM power relay located in the Central Junction Box under the dash panel LH side.
If you have power to the inertia switch , but not after it , try resetting it !
kathyjh
Jul 23, 2010 07:29 PM
big papi
May 24, 2010 07:47 PM
4yeagers
Apr 16, 2008 11:37 PM
