2005 expedition
Old Jan 12, 2014 | 10:03 AM
s_d13's Avatar
Default 2005 expedition
2005 expedition takes several cranks before it will start. had starter and battery checked and both are good. changed fuel pump and driver module and still have same problem. what could the problem be?
Old Jan 13, 2014 | 03:51 AM
Use Common Sense's Avatar
Have you tried to turn the key to the RUN position for 10-15 seconds before cranking the engine. If not, I would try it. You could have a sensor that's not real speedy like it should be. Could even be a failing CRANK sensor.
goiou
May 16, 2009 10:40 AM
jinsoku
Oct 18, 2006 08:38 PM
oldschool1
North East
47
Jan 13, 2006 04:25 AM
waynef1
Nov 9, 2005 09:48 PM
atwooddon
Oct 4, 2005 10:17 PM
