98 expedition a/c and heat on at same time
Old Jul 2, 2007 | 09:55 PM
heyltradesman's Avatar
Default 98 expedition a/c and heat on at same time
whats wrong
Old Aug 13, 2008 | 01:29 AM
robert_l_ross's Avatar
Default RE: 98 expedition a/c and heat on at same time
Could be a leak in the vacuum line that controls the blend door. I have a pinhole leak in mine...when I hit the AC I have to cycle the thermostat from cold to hot back to cold - when the truck is off, the vacuum line leaks when the truck is off, moving the blend door from cold to the middle. Cycling the thermostat moves the door and fixes it - but only when the engine is running (creating vacuum).
Fix - unfortunately replacing the vacuum line and that's a b!tch to do.
Old Aug 16, 2008 | 10:21 AM
andry's Avatar
fill the freon and waiting for about 3 weeks. if the problem come again, it means there is any leak.
Ford_Lincoln_1995_germany
Jan 23, 2015 01:46 PM
daveranger
Aug 24, 2006 03:35 AM
daveranger
Jul 8, 2006 07:42 PM
Woodsman
Dec 31, 2005 01:39 AM
lobsteroll3
Aug 5, 2005 02:29 AM
