same front suspension parts since 92'
Old Aug 21, 2006 | 06:04 PM
daveranger's Avatar
Default same front suspension parts since 92'
I have a 92' Ford Ranger with 2.9 V6. I have the same front suspension parts since car purchased in 1992 with current 220,000 miles. I notice the steering wheel is misaligned with straight driving path of vehicle. I do get abnormal front tire wear also. I never bother with front end alignment. Seems like waste of money.
Should I go ahead and replace certain parts such as bushings, tie rods, bars, etc. since it's been so many years?
Thanks,
Dave
Old Aug 21, 2006 | 07:31 PM
techmanbd's Avatar
Default RE: same front suspension parts since 92'
Having the aligment done is not a waste of money, that is probably the major player in why you have abnormal tire wear.
But you may want to change out teh bushings as well.
Old Aug 21, 2006 | 11:27 PM
daveranger's Avatar
Brian, thanks for responding to my inquiry. I shoould explain why I said "aligning is a waste of money. It seems that the front end can go out of alignment again not long after you have it aligned. Could be driving over a pothole, or driving on unimproved roads to go camping.
Surpisingly, I don't have to change out tires that frequently,and I don't buy the high end tires. I drive carefully and rotate the tires often. I have not aligned my Ford Ranger since 1998 or 1999.
For the sake of giving good advice to the other readers, technically I know your are right. Front end alignment is not a waste of time
Old Aug 21, 2006 | 11:40 PM
rangerman's Avatar
Yeah just have it Alligned.
Old Aug 24, 2006 | 03:35 AM
drw0392's Avatar
I believe the last year with the twin I beam suspension was 97.
Alligning will save you money on gas and tires, techman is right, replace the bushings too.
pfordg1969
Dec 3, 2010 12:22 AM
hotrodstude
Feb 9, 2010 10:29 AM
black95markviii
Aug 20, 2008 07:46 PM
whoyourdaddy49
Feb 11, 2007 07:45 PM
