Brakes are locking up
I have 2007 Ford Expedition my brakes are locking up on me when I press the brake pedal and I release the brake pedal the pedal function is fine I find out when I'm at a light when I go to drive off I feel the brake still holding on to the calipers I've changed brakes calipers and discs I also change the booster and master cylinder I'm still having this issue can someone please help me
Try loosening the master cylinder mount a couple of turns and test drive, if this helps then the brake pedal rod is too long you will need to adjust it.
jimbo142345
Jan 4, 2009 12:09 AM
