check engine light
Old Aug 5, 2008 | 09:26 PM
fitter1974's Avatar
Default check engine light
check engine light on in my 98 expy code reads as po171 system to lean(bank 1) just wondering if anyone can help me with this problem and what it might be, an o2 sensor? Thanks
Old Aug 7, 2008 | 12:23 AM
J.A.F.E.'s Avatar
Default RE: check engine light
It is a vacuum leak. If you are lucky it is just a vacuum line or connector. More likely it is the upper or lower intake gaskets - these engines have a history of intake gasket leaks.
Old Aug 7, 2008 | 10:33 PM
fitter1974's Avatar
Yes it was a vacuum leak, Found a cracked hose behind the throttle body. Thanks for the info.
93redxlt
Mar 18, 2010 04:44 PM
allensimpson
Jan 10, 2008 09:40 PM
farris1307
Sep 9, 2005 04:59 PM
basketbjones
Aug 30, 2005 10:16 AM
bluemq1
May 16, 2005 08:06 PM
