Heater
Old Jan 3, 2008 | 08:38 AM
wsnyder69's Avatar
Default Heater
I have a 99 Expedition EB 5.4L and my heater has started to act up. When I stop at lights it starts blowing cold, but when I rev the engine it gets hot again. Is this a blend door problem? I found a site that has instructions for this, but I don't want to get into it if this isn't the problem.
Old Jan 3, 2008 | 09:58 PM
btexpress's Avatar
Default RE: Heater
Sounds more like a flow problem thru the heater core, it may be plugged up.
Old Jan 7, 2008 | 12:31 PM
oldtimer35's Avatar
Default RE: Heater
Check your coolant level, sounds like it may be low, or your waterpump is not putting out properly.
Old Jan 7, 2008 | 03:41 PM
flyinfish's Avatar
Default RE: Heater
I would suspect low coolant level as well......
Old Jan 9, 2008 | 11:47 AM
BRETM's Avatar
Default RE: Heater
The most common problem on these are the blend door actuator!
Old Jan 10, 2008 | 01:28 PM
oldtimer35's Avatar
Default RE: Heater
The blend door actuator would be constant problem, not changing with engine rpm.
globalwide
Jun 22, 2005 06:42 PM
rugrat
May 6, 2005 03:18 PM
jephinner2
Mar 8, 2005 11:25 PM
casmit
Mar 7, 2005 01:29 PM
iamdoc
Mar 1, 2005 01:21 AM
