hissing sound from brake pedal at fire wall
Old Oct 13, 2007 | 10:56 PM
pesky's Avatar
Default hissing sound from brake pedal at fire wall
I have recently had a hissing from the rubber boot at the brake pedal where it goes through the the fire wall. Part of the booster assembly.It is part of the Vacuum system and there is a hole in the rubber boot that goes around the cylinder. does anyone know what this part is called or how to fix it. I am trying to avoid a costly trip to the dealer.[:@] I have no problems with the brakes but if i mess with the boot and make the leak open up more the truck idle starts to surge but not stall.
Old Oct 14, 2007 | 12:24 AM
Default RE: hissing sound from brake pedal at fire wall
If the booster is bleeding vacuum into the dash area (at the brake push rod), the fix is a booster replacement..
Old Oct 14, 2007 | 08:20 AM
pesky's Avatar
Thanks Hayapower.
So I have to replace the entire booster assembly for a $5.00 part? that figures!!
Old Oct 15, 2007 | 09:34 PM
pesky's Avatar
Can anyone direct me to a good supplier for the booster. I can't find any for the 2003 specifically.
Old Jun 17, 2012 | 07:05 PM
Mr_Udall's Avatar
I was having this same problem. The hissing sound has now transitioned to a squeal coming from the firewall at the brake pedal. Did you have to replace the entire booster to resolve your problem?
vibher
Apr 29, 2013 04:42 PM
jalpern
Apr 10, 2011 09:44 PM
epgarvey
Dec 26, 2007 09:43 AM
doughboyfocus1
Feb 24, 2006 05:08 PM
css
Jan 17, 2006 01:15 AM
