1997 ford expedition
Old Jun 24, 2012 | 03:10 PM
noriegafrank48@yahoo.com's Avatar
Default 1997 ford expedition
why 99% of the time it wont start and those times that it does run you can hear the fuel pump running
Old Jun 24, 2012 | 03:11 PM
i dont want to drop the tank if there is something else wrong with it
Old Jun 24, 2012 | 05:37 PM
If you have the owner's manual check for the location of relay #6 in the fuse panel under the hood. You should feel that relay energize when you first turn the key on and can feel it drop out if you don't attempt to start it. You can also find the inertia switch located at the top of the right side kick panel and give it a whack and you will hear the ball roll as the switch opens. Then just depress the reset button and if all is well the pump should run as expected.
1997fordexpedition
Feb 3, 2013 12:12 PM
BK1997EB
Apr 5, 2008 07:20 PM
BK1997EB
Apr 1, 2008 12:43 AM
joshua1997
Apr 4, 2007 07:48 PM
JGADDIS
Feb 12, 2007 11:12 AM
