Motor problems
Old Sep 21, 2012 | 04:20 PM
KW93551's Avatar
Post Motor problems
Hi everyone, I have a 01 Expedition with the 4.6L in it the original timing chain guides were broken so I removed them and replaced them did not touch anything else except what was required to remove the chains. Now I can not spin the motor with starter or manually does anyone know what could be the problem when I put a wrench on the front it turns only about an inch then stops I can back it up to the same position and it stops. I pulled the pan to see if there was anything damaged on the crank or rods everything looks in order. Any ideas?
nickkiland
Sep 1, 2014 12:18 AM
conanalois
Aug 31, 2013 06:16 AM
apollo
Sep 13, 2009 10:52 PM
arsonist24
Jan 11, 2007 01:00 AM
Project89
Jul 17, 2006 07:33 AM
