Motor/pump running continuously in engine compartment
Old Feb 13, 2009 | 11:04 PM
russ.r's Avatar
Default Motor/pump running continuously in engine compartment
This evening my 2000 Expedition Eddie Bauer had something running under the hood after the key was turned off. It appears to be the device under the brake reservoir - stuck on. This apparently had been running for some time, since the battery was almost dead. The best guess that I can find online is a power brake booster. Any thoughts? I'll be charging the battery in the morning and taking it in for service. Thanks...
Old Feb 16, 2009 | 08:52 PM
Samson's Avatar
If you have rear air suspension then its possible that it could be the compressor that lifts that up and keeps it level. Check the compressor located on the battery side of the Expedition.
makuloco2000
Jul 2, 2014 10:31 PM
mama2clean
May 17, 2010 07:09 PM
mrhogiyogi
Jan 15, 2008 08:03 PM
daveranger
May 24, 2007 12:56 PM
ravenmyst
Apr 19, 2006 01:09 PM
