need help and advice
Old Jul 8, 2008 | 07:43 PM
blackexpo's Avatar
Default need help and advice
hey im new to the site. i want to know how to cut off the air suspension so that i can drop my truck. i looked under the dash board on the passanger side it not there, my expo is a 2001 4.6 expedition. so if any one else knows how to cut it off let me know. thanks in advance daniel
Old Jul 29, 2008 | 12:15 PM
A6 Driver's Avatar
Default RE: need help and advice
You have several componets. Front airs shocks, compressor and rear air bags, level switches at each leftshock.If you want to just stop the compressor either remove the relay or just unplug the compressor. It is on the passenger side front right under the washer resevoir. Several companies make parts to replace the stock system. You will need a OBD II code machine to defeat the "check LVL" code that will flash on the dash.
Christian0001
Mar 26, 2013 07:01 PM
djm1951
Nov 8, 2010 05:19 PM
rachel
Jan 4, 2008 01:39 AM
once_fiestee
Nov 7, 2007 10:14 AM
elizimah
Nov 9, 2006 11:54 PM
