Need help! here's the scenerio...
Old Mar 31, 2008 | 08:36 PM
hoops's Avatar
Default Need help! here's the scenerio...
I have an 03 XLT Epedition. The boot on the brake booster is ripped so I have vacuum leak this will be replaced this week. at the same time I started toget bucking and power loss at highway speeds to the point I had to pull over shut off the truck and start it back up again this would allieviate the problem for a little while. I am thinking the throttle posistion sensor but it seems to happen at the same speeds all the time and now I am wondering if I don't have a tranny problem instead because the problem happens when the gears are shifting notably at 44, 58 and 74 mph I don't know if those are the shift points but it happens at those speeds almost every time. I have even played with the OD vs. D with the same results. I can do this work myself but I am looking for a starting point to chase this down. Any help would be greatly appreciated. Also the CEL light came on probably from the vacuum leak and the last time I pulled over to reset the truck after the power problems the battery light came on.
Old Apr 6, 2008 | 10:48 AM
hoops's Avatar
Default RE: Need help! here's the scenerio...
Well I replaced the TPS and all is well again amazing how a $30 part can bring your truck down. Now the only thing is I lost my cruise control? chasing my tail !!
Old Apr 6, 2008 | 11:50 AM
Thanks for the update..
If you'd like the schematic to start you search and check for power distribution/circuit continuity ect, let me know..
innermotive
Sep 6, 2008 09:29 AM
97fordman08
Aug 30, 2008 03:06 PM
ashleakae
Mar 21, 2008 01:36 PM
bigjay29
Jan 22, 2008 12:38 AM
wannabeprof
Sep 19, 2006 12:13 PM
