Which rear end fluid?
Old Oct 6, 2007 | 09:37 PM
KeithKman's Avatar
Default Which rear end fluid?
I have a 2003 5.4l Eddie Bauer Expedition. The car does NOT have the limited slip rear end. I was looking in the manual and it says to use 75w-90, but below that it says 75w-140. Which should I use?
I located the fill plug and drain plug. Do I need to remove the cover or can I just drain the fluid and re-fill it without pulling the cover off?
Thanks again.
Old Oct 7, 2007 | 03:40 PM
KeithKman's Avatar
Default RE: Which rear end fluid?
Looks like I found the answer.
NOTE WHEN SERVICING THE REAR AXLE ON ANY 2002-2004 F-150, EXPEDITION, NAVIGATOR, EXPLORER OR MOUNTAINEER BUILT BEFORE 3/30/2004, IF FLUID REPLACEMENT IS REQUIRED, REPLACE THE ORIGINAL FUEL EFFICIENT HIGH PERFORMANCE (FEHP) SAE 75W-90 REAR AXLE LUBRICANT WITH SAE 75W-140 HIGH PERFORMANCE SYNTHETIC REAR AXLE LUBRICANT. WHEN THE FLUID TYPE IS CHANGED, REPLACE THE CURRENT "FEHP" METAL TAG WITH A NEW "75W-140" TAG (F3TZ-4121-AA). IN ADDITION, REMOVE OR BLOCK-OUT THE FEHP REFERENCE ON THE MULTI-COLORED LABEL LOCATED ON THE RIGHT SIDE AXLE TUBE. IF THE AXLE IS A LIMITED-SLIP MODEL, USE XL3 ADDITIVE FRICTION MODIFIER IN THE QUANTITY RECOMMENDED BY THE WORKSHOP MANUAL.
nmdoc
Jul 2, 2014 01:27 PM
escaped-eric
Dec 23, 2012 01:33 PM
Crownvicon26's
Nov 8, 2011 07:53 PM
catken
Dec 8, 2010 08:50 AM
CaptJack101
Mar 12, 2008 12:30 AM
