Starter Solenoid
Old Oct 20, 2013 | 02:46 PM
carrocky's Avatar
Default Starter Solenoid
I have a 2000 Exposition and the starter solenoid would click occasionally. I replaced the starter solenoid and still have the same problem. The starter solenoid clicks occasionally. Can anybody please help?
Old Oct 20, 2013 | 03:26 PM
The first thing that should be checked is the battery connections for being clean and tight. Also a good idea to confirm all the ground connections are also clean and tight.
There is a starter relay in the vehicle's "Central Junction Box" ( Fuse panel under the dash, driver's side). When the key is turned to the start position it energizes the relay in the CJB which now sends a power signal through the (formally neutral safety switch) on down to the starter solenoid. When the solenoid activates it sends power to the starter motor. Any one of these places could have a poor connection that would prevent the starter motor from operating . If all those connections /components are OK The starter itself is suspect. Sometimes when this happens where it just clicks and won't start we give the starter a light rap with a hammer and if this now allows it to start ,the starter is usually the problem.
Again, most of the time the problem you are seeing usually is the result of poor connections.
Old Oct 20, 2013 | 04:42 PM
carrocky's Avatar
I will double check battery connections. We cleaned battery connections and ground connections when we replaced the starter solenoid, I will double check them. Thank you and I will try your other recommendations.
trschroeder
Mar 1, 2012 05:34 PM
todd-shelton
Dec 26, 2010 01:12 PM
buymoreguns
Jan 29, 2009 10:36 AM
jdm
Feb 26, 2006 08:38 PM
redtide265
Jun 29, 2005 04:48 PM
