03 mountaineer severe misfiring
Old Mar 30, 2013 | 10:31 PM
robpul123's Avatar
Default 03 mountaineer severe misfiring
4.6l v8 ....165,Xxx miles 8 new coils 8 new spark plugs not cats no o2 sensors runs horrible takes like 5 seconds to get from 1,000 rpm to 5 ,000...it back fires n misses alot
Once it hits 4000/5000. Rpm it goes fast....i need help
Old Mar 31, 2013 | 02:42 AM
Did you just fill up with gas before this started?
If you can't get a fuel filter , you could remove the old one and dump out what is inside and see what comes out, water, dirt ? Empty it in the opposite direction of the arrow , or the way fuel normally goes through it. Look for water or dirt.
Old Mar 31, 2013 | 08:11 AM
robpul123's Avatar
I changed fuel filter and pump a few hours ago....still the same problem
Old Mar 31, 2013 | 09:44 AM
robpul123's Avatar
Ran compression test 1-98 2-100 3-97 4-100 5-102 6-99 7-91 8-98
Old Mar 31, 2013 | 11:39 AM
grindman's Avatar
is it possible to have gotten some wires crossed or developed a vac. leak?
Old Apr 2, 2013 | 07:55 PM
FordLifeSaver's Avatar
With all those issues going on at once there should be a check engine light coming on soon. Get the codes if any presents & if you have a small scanner start by checking your long fuel trim & short fuel trim to get an idea of a vacuum leak.
sully4200
Jan 5, 2020 11:33 PM
makuloco2000
Oct 6, 2013 10:08 AM
blundgren77
Oct 8, 2009 09:48 PM
mybigred
Apr 22, 2008 12:23 AM
dbone420
Jun 24, 2005 12:52 PM
