1998 front end shimmy
Old Jun 2, 2007 | 04:45 PM
crow01's Avatar
Default 1998 front end shimmy
I have a friend witha 98 Explorer, and it has a front end shimmy above 60mph. She has replaced lower ball joints, 2 new tires with front end alignment, all 4 tires balanced, and still a shimmy. We've heard of everything from another alignment to wheel bearings. Upper ball joints were "checked" by a garage, and are supposedly OK. Any help is greatly appreciated.
Old Jun 8, 2007 | 07:02 AM
Use Common Sense's Avatar
Default RE: 1998 front end shimmy
I would double check the tie rod ends. I have replaced numberous tie rod ends to fixa front end shimmy that nobody else seemed to be able to. If it's a whole vehicle shimmy it could be a worn or bound up U-Joint. If it's a 4WD, it could be a front axle shaft joint.
Old Aug 15, 2007 | 01:31 PM
explorermedic's Avatar
Had the same problem and found out that I had to replace the hub assembly on both sides and get an alignment. Fixed the problem. Good Luck
Old Aug 15, 2007 | 01:44 PM
wheelsup68's Avatar
Could be Shocks?; are the tires in good shape with no cupping?
jeffswav
Jun 8, 2011 07:42 AM
BCBEEF
Mar 21, 2008 03:56 AM
sludgemonger
Jan 1, 2007 11:20 PM
sludgemonger
chaud
Apr 27, 2006 12:17 AM
