2000 Explorer 4x4 Noise
Old Sep 4, 2012 | 02:00 AM
qr3379's Avatar
Default 2000 Explorer 4x4 Noise
When in auto mode the car sounds fine, but when I put it in 4x4 high or 4x4 low it makes like a whining noise. I was wondering if there are any grease points or fluid levels to check for the front end? Thanks
Old Sep 4, 2012 | 09:38 AM
bandit1948's Avatar
check the grease in the front pumpkin, it might be pretty low ! there should be a pumpkin like the rear end in the front, take the plug out, stick your finger in the hole and see how full it is !
Old Sep 4, 2012 | 01:30 PM
qr3379's Avatar
I checked the fluid and some came out when I pulled the plug so that is full. Any other ideas? are the axles greasable or are they sealed bearings?
Old Sep 4, 2012 | 03:12 PM
If you can get the front wheels off the ground , lock the hubs, but not the transfer case and rotate the wheels. You may be able to hear the noise and determine where it is coming from. Possible u-joint problem.
uh1dg337
Jan 14, 2014 11:34 PM
music
Oct 24, 2012 06:08 PM
nicknack24
Feb 5, 2008 10:53 PM
haledonoem412
May 6, 2007 06:10 AM
jonny3781
Mar 25, 2006 07:44 PM
