2000 Explorer, climate control system will not shut off
Old Nov 13, 2006 | 05:29 PM
bdel10's Avatar
Default 2000 Explorer, climate control system will not shut off
I recently purchased a 2000 Ford Explorer Eddie Bauer Edition with high mileage for my son for his first car. All of a sudden the climate control system will not shut off. When you hit the off button the display will go out but the blower stays on. Whe you hit the thumb wheel for the fan the lights come back on. You can still adjust the temperature but the fan will go higher when you turn it down and vise versa. Any ideas what is causing this or is it just a bad unit?
Old Jan 11, 2007 | 09:39 PM
yorkie's Avatar
Default RE: 2000 Explorer, climate control system will not shut off
Have a 2000 Limited I bought used. Climate control developed a similar problem. I did purchase a warranty with it. Shop just replaced it saying the unit was bad. Cost was $600 BUT I paid only my deductable of $100. IT's not cheap if you have to do the same.
Old Jan 11, 2007 | 11:59 PM
wheelsup68's Avatar
Somebody recently posted a procedure to pull flash codes or reset these auto climate controls in a Taurus. Mabey you could check out the Taurus section to dig out that procedure and try it on the Explorer.
gveinot
Apr 9, 2013 07:29 PM
TerryP
Oct 4, 2008 09:42 PM
1993sho
Feb 12, 2008 01:09 PM
rc10mm
Nov 13, 2007 12:19 AM
cwoodul
Dec 5, 2006 10:30 AM
