2003 explorer v8. 4.6
Probably the typical Ford power steering pump whine. Fluid warms up then the pump quiets down. A P.S. fluid flush and fill with the proper fluid won't cost much, is a good preventive measure and might solve your problem.
Usually when an idler pulley bearing fails, you will see some powdered rust coming from it.
