4x4 light flashing
Old Dec 18, 2012 | 09:36 PM
helrazr3's Avatar
Default 4x4 light flashing
hello all im here helping out a friend who's not so good navigating the web im re posting a question he had in the new member area so here goes
New at this: I have a 2004 ford abs light is on and appears the 4x4 light flashes eight times aprox. every two mins. Does anyone know what code this is. Thank you
Old Dec 21, 2012 | 11:19 AM
mxpxpunkrock1987's Avatar
To all you people who have blinking "4wd" and "4wd low" here is a little story for you.
for about 8 months now I have had the 6 blinks every minute symptom where it seems to shift into 4wd OK but after a few minutes the lights start blinking and I am not sure if it is in 4wd or not.
Well I took it to the dealer and asked for a diagnosis. after a $75 dollar charge they told me that the computer registered an "internal clutch solenoid error" and that i would need a new transfer case. The mechanic was very nice but told me it was considered a "non- serviceable item". They did very little investigating to come up with this answer.
To make a long story short, After a lot of research on my part (some on this forum). I figured out that there was a 90% chance that one of my HALL sensors had failed. I also found out that every dealer in the world knows these sensors fail. There are dozens of stories on this forum that detail this.
I bought both of them for $30.00 each. I changed the one on the rear driveshaft first. it took about 10 minutes to clip the wires to the old one. Butt splice a new sensor in. Install it and paint the connections with some liquid electrical tape. this fixed my problem immediately. I never got to install the front driveshaft sensor.
It seems like Syosset Ford is the only dealer in America that doesn't know about the HALL sensors on the 44-05 transfer case.
I also paid them $800 dollars to fix my ABS brake system. That was probably a $20.00 sensor also.
I still have the front sensor. If anyone wants it I would be happy to mail it to them.
Thanx for all the advice
Old Dec 21, 2012 | 10:47 PM
helrazr3's Avatar
well i guess thats a good place to start thank you for sharing the story.
Old May 18, 2013 | 07:04 AM
HocusFocus's Avatar
Default 4 x 4 light
Wow I got the same problem.
Can you tell me where on the vehicle the sensor is located. thanks
Old Sep 13, 2013 | 11:28 PM
Godspeed's Avatar
Default God send...
Thanks for the suggestion I'm glad to be acquaint with people like yall!!!
tomcat5
Aug 10, 2021 05:10 PM
JayB954
Oct 23, 2009 08:16 PM
cnixon19
Dec 21, 2008 10:18 AM
ajrn
Apr 12, 2005 05:16 AM
