94 explorer dr side window help
Old May 18, 2013 | 04:26 PM
moe35's Avatar
Default 94 explorer dr side window help
Driver side window will not go up or down I replaced switch twice.. new switches when I pushed driver side switch pass side window would go down in auto mode . no response from driver side window ,,,Manger at auto zone told me ford used two different switches before and after feb of 94... he did not have any access to the one prior to that date... no noise from inside door and the dome light does not dim... can anyone help?
Old May 19, 2013 | 04:43 PM
You may have to remove the door panel to confirm power is getting to the motor on the driver's side. If it is , then there could be a problem with the motor itself.
jdijon2000
Feb 3, 2008 10:18 PM
tommyp35
Mar 19, 2007 05:12 PM
Davetheslave
Aug 30, 2006 09:36 PM
MizzouGuy
May 22, 2006 02:43 PM
