ABS and Traction Control light
Old May 27, 2014 | 04:28 PM
LAUDERMAN's Avatar
Default ABS and Traction Control light
I own a 2004 explorer xlt with the advtrac system. I have a constant traction control light off with an abs light after driving a few hundred feet. I have replaced both front hub assemblies as well as all 4 wheel speed sensors. My local repair shop is out of ideas. Any ideas out there??
Old May 27, 2014 | 04:29 PM
LAUDERMAN's Avatar
Is there a sensor on the transfer case that may be causing this issue?
Old May 27, 2014 | 10:44 PM
Use Common Sense's Avatar
You may have a bad "Brake Pressure Switch". It is screwed in directly under the master cylinder.
artcat99zl
Jun 11, 2015 09:07 AM
chovek
Nov 30, 2014 11:07 AM
Justin7666
Apr 11, 2008 02:04 PM
rcook
Feb 11, 2008 10:44 PM
