Another crank no start
It cranks fine but doesn't start. I know I need a fuel pump but I spray starting fluid into the air intake and it doesn't even try to start. It
dumped two feet of snow last so everything will have to wait until I can dig everything out. I am thinking the crank sensor or the coil pack. The fuses are ok and so is the relays. I just put in a new ign switch so maybe it is out of adjustment? better spelling |
It is the crank sensor, although. The connectors are suspect as well
Hang in there, spring is around the corner, so they tell me.
it was the crank sensor and the connector, plus the holding clips on the coil pack were missing so i changed that as well. now when i spray starter fluid in it fires right off.
