Another crank no start
Old Jan 15, 2020 | 03:05 PM
fastonraceday's Avatar
Default Another crank no start
It cranks fine but doesn't start. I know I need a fuel pump but I spray starting fluid into the air intake and it doesn't even try to start. It
dumped two feet of snow last so everything will have to wait until I can dig everything out. I am thinking the crank sensor or the coil pack. The fuses are ok and so is the relays. I just put in a new ign switch so maybe it is out of adjustment?
better spelling
Old Feb 8, 2020 | 09:31 AM
It is the crank sensor, although. The connectors are suspect as well
Old Feb 8, 2020 | 09:39 AM
Hang in there, spring is around the corner, so they tell me.
Old Aug 5, 2020 | 01:06 PM
it was the crank sensor and the connector, plus the holding clips on the coil pack were missing so i changed that as well. now when i spray starter fluid in it fires right off.
1780 bell
Dec 18, 2012 08:40 PM
fordman83
Nov 28, 2010 08:04 PM
rancherogt1973
Oct 5, 2009 03:10 PM
BJB
Feb 4, 2008 07:16 PM
FordNutz
Dec 14, 2007 11:37 AM
