Ball joints 04 explorer
Old Nov 21, 2008 | 05:14 PM
bobjan's Avatar
Default Ball joints 04 explorer
Are these fairly easy to do they dont look to bad to change ????
Old Nov 29, 2008 | 05:05 PM
techford's Avatar
Default RE: Ball joints 04 explorer
Hi, the upper table is pretty easy, you might have a little problem with theupper tablebolts to frame, but you should go thru it!. For the lower ball joint, you want to remove the knuckle/spindle, what ever how you call that. Then, using a stand or a jack, you support the lower table, remove the snap ring and using an hammer you tap the ball joint downward.
Nic.
Old Dec 9, 2008 | 04:48 PM
oldtimer35's Avatar
How about control arms?
fitter1974
Jan 31, 2009 10:23 AM
homegrownrmk
Aug 1, 2008 06:11 PM
e250extended
Dec 24, 2007 12:32 PM
pgh2160
Nov 8, 2006 02:09 AM
oldschool1
Nov 8, 2004 12:25 AM
