BETTER GAS MILEAGE
Old Mar 12, 2007 | 09:28 AM
  #11
braydee0521's Avatar
Default RE: BETTER GAS MILEAGE
GOD BLESS YOU THIS IS GREAT!!!!
Old Mar 12, 2007 | 10:20 AM
  #12
More than likely it would be the sensor gone bad and not the sender... right?
Old Mar 12, 2007 | 07:59 PM
  #13
goinstrong's Avatar
Sensor and sender are basically the same word.
Old Mar 12, 2007 | 08:43 PM
  #14
goinstrong's Avatar
Temp. sensors are usually either located on the intake manifold or the engine block. They'll either have one or two wires attached (in most cases one). When you remove a temp. sensor it will leak a lot of antifreeze so have the new one ready to put in (or better yet drain the antifreeze first). If the antifreeze gets to be a mess - pour a cup of water over the mess to thin it out. Antifreeze let to dry on wires will likely cause short circuits and grounding problems.
patterbery
Feb 12, 2013 07:49 PM
BigRedFord
Feb 24, 2010 07:08 PM
berning.36
Feb 26, 2009 03:43 PM
firesheriff
Mar 6, 2008 09:08 PM
xkikbxr
Nov 3, 2004 02:14 PM
