Blower Fan issue
Hello everyone, I have a question about my blower motor fan. About a month ago it would quit working out of the blue, a quick punch on top of the dash fixed that. Now when I start it up, it will turn on but then about 30 seconds later it slowly dies down then it makes like a chugging noise. Punching the dash no longer works and now my hand hurts. Does this sound like a relay problem or a fan issue? Thanks.
Oh yes, it's a 2013 limited. I have tapped on the fan and it didn't do anything.
Most likely you will need a new blower motor speed control, its the computerized version of a blower motor resister.
Its a small silver box above the blower motor, has 4 wires going to it, held in by 2 screws.
I would recommend sticking with a motorcraft one, aftermarket ones dont seem to last very long.
I checked the relay and fuses, all good there. I took off a long bar thing to get to the blower cover, was trying to disconnect it until I realized it's an airbag. Also what size are the bolts on the cover? 8mm is to big and 7mm is to small.
I cannot recall if you have to remove the glovebox to access the blower motor or not, I would check under the dash on pass side before removing the glovebox, watch a few youtube videos about removing the glovebox before you do so, super easy to screw up and break the tabs on it.
I do not know what long bar you are talking about nor why you are remotely touching the airbag.
I had to remove it in order to get access to the bolts that are holding the cover on, I just don't know why my sockets didn't fit the bolts. I'm just going to take it to a mechanic because I don't mess with airbags.
